N
NM
That is exactly how I have been doing the Nytro's. You could run it through either rail first as long as all the fittings were big enough for adequate supply. I ran fuel through the extra injector rail first on my Apex because I have the stock inlet fitting on the stock rail.So, trying to understand this fuel system. Is the flow sequence as follows?.....Tank, pump,OEM fuel rail, Aux injectors, and then a fuel regulator with a return to tank?
