Boost Controller
M
Mcx Nytro
Just bought the turbo xs BC-HPBC talked to Rally sport about it and didn't get any real answers.:mad: So when you put this on do you turn the wastegate back to stock setting??? about 14 lbs on the mcx.
This has a course and a fine adjust but they didn't know how much difference each turn will make:(
Anyone who has a boost controller any ideas????Thanks
This is the only type of controller I know about. Is this is the one you mean?
You can turn the wastegate rod out. Then you can lower the boost down to about 8 with the boost controller at minimum and turn it up as you desire.
But don't turn it up past your map settings,if you're to mapped 15 psi,don't go past that.
