Boost & Cams
turbo800
If your not first, your last - Talladega Nights
K guys, looking at a RX1 with stage2 cams in it. I want to add boost down the road, do these two play nice together or would I need to find some stockers? I have never done a 4stroke before, but would like to try one out.
any idea whos cams? if they were made for a n/a motor they will work but you wont see the gains they made when used without a turbo. you dont want much overlap in a turbo motor so it can stuff more air into the cylinders you would need to talk to the cam maker to help you better,you mite be able to change the cam timing to help with that.
Hotcams Stage2. Yes they are in a N/A motor right now. Are you saying with in a boosted 4stroke they could have too much overlap?
not sure thats why you would have to talk with them, they could tell you just let them know you want to run them in a turbo motor .you may be able to just re-time them to get the gains back out of them & they may work just fine the way they are,but only the cam maker can tell you that.
