Boost and Clutching/Fuel Controller Changes....
As you change boost levels do you have to change the clutching and fuel controller settings too? Or, do you rarely change how many lbs you're running.
I've seen a few people comment about having too much HP (wheelie too much, sh**ing pants, etc) and maybe depending on conditions or location they may want to dial it back.
Could dialing it back be just that easy, or is there more to it.
I clutch for the highest boost i will run and if i dial it down the clutches just don,t shift out all the way .
Once you have your fuel system dailed in for your highest boost , you should not have to change it because you turn your boost down , you may have to alittle because of air temp. or elevation .
Curtis
