Have a 12 pro with the pump gas turbo no innercooler, has controller with built in ebc, it has a 6 pound waste gate, with the ebc set at 6 psi the max pressure is showing up to 9.2.psi checked the ebc plumbing looks good, the waste gate seems adjusted correct. Boondocker has been very helpful but has anyone else come across this, if so how what did u do to fix this thanks. The sled run really good at this with good afr numbers
