I got a 2012 SBA 144" is there a delete kit for the rear outter bogies? or does one just take them out and put another in the middle?
you talking bogies on the rails or idlers at the back??
I made a two wheel kit for my SBA using the factory parts. You have to flip the adjusters to the inside first. Then, you have to trim the inner aluminum spacer down, by the width of a wheel bearing. This will make room to put one of the outer wheels inside. The hardest part is cutting down the inner axle so it's only as wide as the rails themselves, then drilling and tapping a new hole so the bolt will thread into the cut end. Check out my build thread, page 2, I have some pics of when I did it. It's on rail extensions, but works exactly the same as factory rails.
http://www.snowest.com/forum/showthread.php?t=311717&page=2
