I have a 16 Axys I bought used this summer. It has 600 miles on it and is a 163 2.6" track. Out riding in Buffalo Pass around 9,000- 10,000 feet.
The first issue is it didn't want to idle very well. From reading it sounds like a tps adjustment. Which sounds simple enough to fix that.
The second issue I have is a bog around 5500-6000 Rpms. it seemed like it was the most noticeable on the trail ride out in the mornings. Not as noticeable while riding but then again I'm not keeping it steady in that rpm range. And it wasn't as noticeable on the trail ride in. Gonna try cleaning the exhaust valves when I get back home.
I also was only hitting around 7900 Rpms with 10-60 epi belly buster weights. All other clutching is stock. I switched to 10-58 epi belly buster weights and saw a little increase to 8000 rpm but that was also 2 feet of more snow between those two Days.
While looking over the sled I did see that some of the wires going to the relays on the cross member were rubbing on the GPS bracket.
The idle issue seems easy to fix. But I would really like to eliminate that bog and see my Rpms more around that 8200 rpm range. Looking for some recommendations and insight. Thanks.
