The last few times ive been out ive noticed the sled isnt starting as well as it used to. Its a carb and when its really cold it takes about 5 pulls to start, no biggie. But once I let it run for about 20 seconds with the choke on I turn the choke off and the revs get lower and lower. If I try and feather the throttle to get the rpms up it just bogs and bogs and eventually dies. Yesterday I had to start it 3 times and leave the choke on for about 30-40 seconds each time before it warmed up enough to turn the choke off and throttle it up. After that it runs fine all day long and starts first pull.
It never used to do this, I used to start it with the choke and then be able to switch the choke off after about 10 seconds and it would idle fine.
Not sure if its related but my throttle also seems to be getting stuck open slightly. Most noticeable coming back on the trails, when cornering I release the throttle but the sled continues to run at about 5000-6000 rpms. I am having to lock the brakes up to get it to idle back down to ~3000rpm. We tried running de-icer in the fuel but this didnt work.
Can I lube up the cable somewhere to help fix this do you think?
