stingray719
I bought an Apex years ago that unknown to me had been ran out of oil. By that I mean you can lay an Apex on its side and run it with no oil pressure until you can get it shut off. No way I know of short of disassembly to check for that.
Sooooooo about third time out it made a lifter sounding noise (clearances are so close a loose rod will clip the lower case). I tried to nurse it back and it locked up. I had to replace one valve, piston and rod, and the crankshaft. Please note this is NOT an easy engine to rebuild, the rod clearances are so close you won't believe it.
I strongly suggest another engine as you are going to have to do a case and you cannot just replace the bottom half of the case as they are machined/matched. Time you buy case, crank, head you are up to price of used Apex...........
