how much do you think you can get out of a blown up apex......... you get everything including boondockers turbo......its a 2007 ....... not sayin im selling it just wonder what I could get. any ideas??????
I dont know it's was only my fifth time out And I was only running 12 pounds with 50/50 mix and everything was set up to go ........ Its disappointing cuz I'm 18 and don't have alot of money to fix big problems like that..... I guess it could be a life lesson hahahaha
I had the same basic scenario about a year ago. The sled I bought had a motor that was hurt/junk/??? motor and after just a couple times out if went the shat. Heres my advise. Dont be scared. These things really arent that bad to work on. Dive in and figure out what went south and fix it. You will be supprised at just how simple they really are.
Secondly-
What does or doesnt it do? Turn over, run at all, locked up solid, hole in block, etc.
it has a head shim......... im pretty sure it was the bottom end.... the piston rod blew a hole through the whole bottom of the engine (about 4 inch wide hole) ......... all in all the sled blew up and no longer turns over ......... and im positive it was not over boosting because I had just checked how much boost I was running. and thanks for the advice I appreciate it a lot
I was going to say the apex motor is something I wouldn't dive into. Everything is expensive and if it falls apart the 2nd time out because you forgot the proper TQ sequence on something its even more expensive. Look for a used motor run the boost at a more conservative 8-9lbs and have fun with it. Save money if you want to run more then 10lbs.
