Blown Motor On My Nytro
LMFAO !!!!!! So let me get this straight, so far this year Mr ApexMan has burnt his turbo Apex down to the ground, over boosted and blew up a Nytro demo, then goes out and over boost's his own Nytro ?
OMFG, Hahahahahahaha.
Darwin awards, we have a contender LOL.
It is bad luck to post here. Very bad juju!
Can I catch stupidity from the originator of this thread?
What shop is taking care of this guy? I think they are due some business for going beyond the call of duty for thier customers. They seem to be pulling out all the stops to help make things right no matter what the cause. Everyone talks a good game about customer service, few actualy pull through once the money has changed hands.
man you fuggers need to lay off this guy a bit,his post was a little miss leading,lets give him a break he already bought 2 sleds this year,and casey just for the record i have run 18lbs on chevron fuel lots,on my apex 3600kms no problems,i dont make a habbit of it but when my buddy shows up with his alpine apex,and wants a shot at the title,the last thing that goes through my mind in fuel!!!! JUST PINN HER MAN TO THE TOP!!!!!I might be rolling dice but i will worry about that later!!!! P.S by the way myles is one of the best!!!
The thing I can't figure out with all this is that a sled that has clutching dialed for 12-14psi (if that was what it was supposed to be at) is not going to run at 18 psi without being on the rev limiter.
I just got off the phone with Myles, and I gotta say that the way apexman brought this up I was doubting it a little bit, thus the reason for calling myles. The nytro kit is supposed to be like the 07 apex kit and shut the boost off at 12-15 pds. Myles never told apexman that he was good to go on 18 pds boost with premium fuel. He did set it up for that 12-15 pds boost, and he did tell apexman to go out and have fun. whether it's miscommunication or whatever, these sleds should not be run at 18 pds boost with premium fuel. there has been 2 of these cases reported from Myles, apexman's and Myles demo sled. also, there must have been a couple of kits that Myles recieved where the actuator rod was too short period, and didn't have enough adjustment, thus apexman's comments on the rod being to short. Myles is understands the situation fully, and is on top of it. Darko is right in everything that's been said, just the way this thread was brought up made it a bit confusing. Thistle, Myles understands everything about mc kits. you may think different, that's fine. he's taking responsibility for this learning curve and making it right for apexman and avoid these being set at 18 (accidentally) in the future. hope this clears this up.
OK So they dyno this thing....it makes 18lbs boost on the dyno?? Or did it magically go up once he hit the hill?? I know myles has put lots of turbo sleds out but this just doesnt make sense...And when darren had it to the bar he saw 18 so why hold it?? Like everyone else said....we all know 14ish is pushin the bar on pump gas.
when Myles dyno's a sled, it's to see exactly what kind of power a sled is making. He does this to make sure he has the optimum setup and the sled is running the way it should be. now whether darren saw this and why he did 5 runs at 18 pds boost on pump gas is beyond me. I know for a fact that Myles would not tell you to run your sled at a boost level that is beyond what it should be running. according to myles, the nytro kits are supposedly supposed to be like the 07 apex kit's where the kit is regulated and only supposed to run a maximum amount of boost before the kits bleeds off the excess. after talking to Myles, the nytro kit apparently is not doing this, and thus the reason for the 18 pds. he mentioned something about the actuator rod beng to short(I dont know if it didnt' have any more adjustment, or if the rod itself was too short from MC X) thus the sled is pulling way too much boost. Because of this, this is why Myles is standing behind his install(top notch and above what he should be doing) and keeping Mr Darren happy. from what I gathered, Darren should have noticed this 18 pds (especially on a first ride on a brand new sled) and should have backed the hel! out of the throttle especially running pump gas. Myles did not tell Darren to run this thing at 18 pds boost on pump gas. So, Darren consider yourself lucky that you have a top notch dealer looking out for you.
Ok,,,so Apexman,here's something you might not know about EFI and turbo's,and you have find out this BEFORE you even ride your sled,if your mapping is NOT set up for 18 psi,you CAN NOT run 18 PSI,,,ever,,,even with race fuel,the mapping does not know how to give the engine more fuel at 18,I suspect it had stock mapping and the map only knows how to deliver fuel at that map preset,if you go over,it will not deliver enough fuel,period.So make sure with the next engine,what the mapping is set for,but anything over 15,regardless of the map set,you will need race fuel.
With the Vector and Nytro,lean overboosting will lead to rod failure first,then with very little warning, the rod will snap and go through,you will hear it first,and if you can react in time you will save the cases,(ask me how I know)and it's almost always the center rod that goes.
As for Yamaha paying for cases,they know EXACTLY what causes this failure,don't count on warranty.
Linc, The mcx nytro's are mapped up to 18.3 lbs. He would have been ok if he was running straight 100ll.........and he knows that now, RIGHT:)!!!???!!!
not sure if i understand this, you were aware of 18lbs boost and knew you had premium pump gas in the tank? i feel kinda sorry for your dealer for putting together such a sled for someone who doesn't understand anything about boosted sleds. you were over 300 hp with an engine the size of a lunch kit on pump gas. i just bought my nitro 2 months ago with stage 2 sc, and within the first day of owning it i researched all i could about running this class of sled. here are some tips for the future, correct me if im wrong guys, but this is what i understand. 8lbs of boost (175hp) safe on pump fuel at 3000 ft. 10lbs boost should run 50/50 race fuel, 10-12 lbs boost fine to run at elevation with head-shim which drops your compression a bit so pump gas is ok. 15lbs boost, 50/50 race fuel......after 16lbs boost, carillo rods and aftermarket pistons should be added (some guys have luck over 15, but most agree thats pushin it for stock rods and pistons), 18lbs of boost, should be straight race fuel, maybe headshim allows 50/50 at this point, but the nitro cannot supply fuel with factory fuel system at 18lbs boost so fuel system upgrade including fuel regulator, fuel pump, and in some cases changing injectors are a must. who would spend over 20,000 on a sled and not do some research, but i guess it shows that in the wrong hands, even a bullet proof machine doesn't stand a chance. and if you have 20,000+ to spend on a sled whats the problem running some race-fuel. im running straight race fuel just caus im too lazy to mix, but its a small price to pay. i used to burn premium + $30 worth of synthetic 2-stroke oil in a day, now no fancy oil to burn so i put the money into better fuel. good insurance. maybe i misunderstood whats going on here, but its my .02
Supercharger are quite a bit diff from turbos....no head shim no cold air and mpi....sounds like a 3 handicap to me:D
the point was that it wont overboost and maybe better for a person that doesn't know what boost means in terms of fuel and hp. i know mcx is a great kit, and probably a better hill climber, head shim? its like adding compression with boost then taking it away with more space in the combustion chamber, more to run poor fuel than anything else. cold air? they have intercoolers! as far as mpi, dont know yet, no troubles yet but from what i hear, it took them awhile to get their chit together. aparently the stage 1 is working great but stage 2 goes beyond the limits of the stock fuel system, and this would go for anything turbo or sc making 280hp. does mcx come with a fuel pump and regulator? the stage 2 sc should and it doesn't. flappin your gums just shows your bias, not fact. do you think mcx coming with a linkage rod too short, making 18 lbs boost instead of 14 is the sign of a good company? pull your head out of your a$$ and see the fact that whatever kit you choose can have its problems when your running on the edge soo far beyond stock horsepower, there will be some problems. but who has blown a motor with a sc? the only problems they've had is their pulleys coming loose, which they've sorted out a long time ago, and their fuel mapping on the stage 2, which requires the use of a fuel pump and regulator. but if your over 6000 feet the stock fuel system will keep up, but just barely.
my .02
Wow,, they come premapped to 18 psi! At any rate, that philosophy stands for any mapping set,If it isn't mapped for it,,, don't go there...EVER.
Yup,,, 100LL would have been a safer.
I think the guy has been beat up enough now,he's going to so freaked about fuel now.
The MCX system should never leave the shop without the extra fuel pump,this happened to one of my customers,he pushed it to 22 psi and sliced the pistons open( Apex)and the reason is the fuel system can not supply the fuel needed for anymore than 15 on the stock pump,,,,by the way I told him NOT to go past 15,,,that's why we spend money on a boost gauge.
Only 35,,,mine was set at 45,,,clutches ,tires and transmissions lowered my boost.
my .02
Actually FACT they have more than just pulley prolblems...3 pages of problems I downloaded them for my buds that ride the sc..And yes they have an intercooler but where do they draw air from???Under the hood. So not only are they drawing hot air but then compressing this already hot air adds to this problem..And yes I AM biased towards the turbo. When I decided to go boost I read the many thousands of comments about turbo vs sc and I found a LOT more problems with the sc. I would have thought that a company would have these bugs worked out after 5 years of working on the product, and not let the customer figure it out and NONE of the repairs to the 3 pages are covered by them, The mcx box sucking water is fixed by my dealer as is the bigger sock to stop the icing:eek: And yes the mcx did come with a bigger fuel pump
only 45! mine will peg the 60psi isspro in a blink of an eye! I see 45psi towing the trailer ......can I put twins on the nytro!! LOL
-Robert
