Bikeman Pipe & Can Dyno Test Results
OK, I spent half the afternoon at BMP Bikeman Performance in Osceola WI. I brought my stock D8 with the MBRP pipe installed and the PCV with Dynotechs map. All of the dyno time was done by Joe Strubb and he was a top notice tech & tuner. All of the test combinations and results are posted below.
Please remember this sled had the fall update done by Polaris a few months ago and only has 14 miles on it. The sled has the orignal break in tank of mixed fuel in it as well. Yes the ethanol wires were plugged in. I have included the dyno charts below with some pics. We made 18 pulls in total with changes as we went. I have not scanned all of the dyno result sheets since there were many changes that did not do anything worth reporting.
1. The 1st pull was stock tuning with MBRP can that we welded a O2 bung onto it for af readings. The results peaked at 136.9 hp at 7400 rpm
2. The 2nd pull was stock tuning with MBRP can as listed above. The results increased and peaked at 137.8 hp at 7600 rpm
3. The 3rd pull was stock tuning with MBRP can as listed above. The results slightly decreased and peaked at 137.6 hp at 7600 rpm
4. The 4th pull was stock tuning with stock can. The results increased and peaked at 138.8 hp at 7700 & 7900 rpm
5. The 5th pull was stock tuning with stock can. The results increased and peaked at 139.7 hp at 8000 rpm
6. The 6th pull was stock tuning with stock can. The results were the same as pull 5.
7. The 7th pull was stock tuning with BMP can. The results decreased and peaked at 139.6 hp at 7600 rpm
8. The 8th pull was stock tuning with BMP can decreased slightly from pull number 7
9. The 9th pull was no longer stock tuning but with the PCV power commander 5 with dynotech Jims fall map tuning with BMP can. The results increased and peaked at 147.5 hp at 7900 rpm
10. The 10th pull was with the PCV power commander 5 with dynotech Jims fall map tuning with BMP can. The results decreased and peaked at 146.8 hp at 7900 rpm
11. The 11th pull was with the PCV power commander 5 with dynotech Jims fall map tuning with stock Polaris can. The results increased and peaked at 148.9 hp at 7900 rpm
12. The 12th pull was with the PCV power commander 5 with dynotech Jims fall map tuning with stock Polaris can. The results decreased and peaked at 148.2 hp at 7900 rpm
13. The 13th pull was with the PCV power commander 5 with BMP's fall map tuning with there BMP single Pipe and stock Polaris can. The results increased and peaked at 150.9 hp at 8200 rpm
14. The 14th pull was the same results as pull 13 with no results with small pcv map changes.
15. The 15th pull was all most the same results as pull 13 & 14 but was down 0.2 hp to 150.7 hp at a higher 8400 rpms. No other changes.
16. The 16th pull we changed back to the BMP can, PCV with BMP fall program with their pipe and the results decreased down to 149.1 at 8400 rpm.
17. The 17th pull with slight pcv map changes the power decreased down to 147.8 at 8200 rpms. No other changes were made.
18. The 18th or last pull with slight mods to the BMP map for the PCV where we leaned it out on the top with BMP Pipe and stock Polaris can we had the last increase of 151.5 hp at 8400 rpm.
We confirmed many conclusions during the dyno session. The first is that Jim's maps from Dynotech are pretty good, safe and relaible. We also confirmed what Jim has told me many times that most of the cans are too free flowing or loose and lose power but safe weight.
As for Bikemans Pipe mods claims of up to 12 hp to a stock pipe on a stock sled they do have good gains but in general it is few and far between. The BMP single pipe in this case did add about 4 hp with tuning help from the pcv but made the power band much more usabl power then the stock pipe with jims map.
I was impressed with Bikeman Performance and did buy one of there ceramic coated pipes. I am happy that my sled is dialed in to go to Cooke City tomorrow but thought I might be closer to 160 hp? My sled still needs to break in so maybe it will increase another 2-3 hp but I will not see 8-9 hp.
Today in MN & WI was a good day for dyno tuning and the air fuel readings running the sled stock is scary lean IMO. The PCV sure brings the sled to safe air fuel levels and the power on the top helps too. I would encourage any one who owns a Polaris 800 CFi with bog, lean, surge issues to save some time and down time costs and buy a PCV.
If you have any questions feel free to ask. I will post another thread next with the rest of the dyno result pics.
![09D8R7.jpg 09D8R7.jpg](https://www.snowest.com/forum/data/attachments/87/87809-ee18fcb74f7a0ce30d80020b4eaadb4d.jpg)
