big wheel kits r cool!
big wheel kit put about 1 to 2 more luge on the ground which in turn gives u better traction
No,
When you increase the arc from the inside you actually lose bottom surface area.
Bigger wheel = less foot print.
The theory goes...It SHOULD remove rolling resistance by pulling the track around a larger diameter, less of a forced bend in the track.
But unless there is actuall Dyno proof to say otherwise, it is only good for the "Bling" factor...Nothing else. :rolleyes:
Think about it.
If you threw a garbage can in the middle of your track how much LESS track is actually touching the floor?
Might as well put spinners on all your bogeys.:cool:
