Wait so is the accessory plug in 12v? Is that enough power to put in this box, because it's powering my oil pump and AFR gauge and parcially my fuel pump.
I suspect so, but I don't know what your oil pump and AFR draws. If you put it all on the circuit put a volt meter on the circuit and see what you have for voltage. If it maintains about 12 volts then you probably will be fine.
I don't use the mechanical reverse(diamond lite) on my TM8 so I have all the power from the red/black and red/blue tied together. I don't run an electric oil pump, but I do run an IC fan.
Alright so I just went to check my wires just to be sure... And the accessory wire on my sled has resistance between the positive and negative, and the positive and my chassi, does that mean my wire is shorting somewhere or is this wire for some reason supposed to have resistance?
Also Polarisrocks (Jim) give me a few days to see if I can figure it out with what I have but I might just take you up on that offer.
