P
product tester
nice job dave looks like you put the parts to good use...
Two problems I see with a turbo xp, carbs and TRA.
If they can get the DPM to still work with a turbo then it shouldn't be AS finiky but I still think the EFI's would be more friendly.
I also thought that the TRA wasn't holding up to boost very well which is ONE of the reasons Doo isn't coming out with the xr1200.
Personally I miss the built proof P-85.
Different Dave, but Dave Bell's sled does seem to work very well.
Dave Halverson
Never noticed it was not your kit in the Vid till you said that my bad.
So do you have any vids of your system???
If its going to be a weekend let me know Dave. I wouldnt mind making a drive and seeing it go.
If you have no lag you have no turbo, there is no such thing as no lag especially on a 2-stroke turbo. If it is set up properly it can feel like the lag is not there but if you watch the boost gauge you will see the boost is not there when you crack it open off of idle.
I have built a few turbo systems on 4 strokes the can make boost with no load on the motor and at low rpm, you can not do this with a 2-smoker because you can not undersize the turbo on them
As buddy stated above the more boost you run the fatter your clutch weights have to be and the less low end responce you will end up with.
The trick is fuel managment, a good clutch setup and keeping it under 12 pounds of boost, the lag will still be there but it won't seem like it is, just don't say there is zero lag because it is not going to happen on a 2-smoker.
