That is the pitot jet. It is supposed to be there. I think its purpose is to pressurize the fuel bowls??? There should be a hose coming off of the top and heading to the carbs. As the boost rises, so does the pressure in the fuel bowls. It is used for fine tuning the carb settings for changes in temp and altitude. The bigger the jet, the leaner the sled runs and vise versa.
I have a Bender Stage II and found that it really doesn't do much. It is just for fine tuning.
If you are checking for boost leaks, check the charge tube that runs in the tunnel. I pressured up my system and had a bunch of leaks in the tunnel. When I pulled the charge tube, the mount tabs for the tube was torn and leaking BAD. There were two or three of them with 2"-3" tears. That was a bunch of boost being lost.
Lance
