The stock set up seems to build a fair amount of heat. I saw 50-60 degrees when riding deep snow in Blue River. Working on a multi-angle helix/ spring combo that will reduce temps and rpm fade on long pulls.Anyone else getting low km/miles out of there gen5 turbo belts? I only got 500 miles and a ridding buddy only go 530 miles.
I got 490 miles on one belt 380 on another and my buddy got 410.Anyone else getting low km/miles out of there gen5 turbo belts? I only got 500 miles and a ridding buddy only go 530 miles.
Yeah probably going to do ibackshift clutching next yearIs this with stock clutching?
I took mine off just extra weight don’t sit much anyways.I find it very interesting that this wasn't discussed until the bear was poked. Has anyone else developed a rash from sitting on the low profile seat on the 2023 expert turbo r??????
Had a stage 3 tuned 2020.5 turbo original belt still on the sled when I sold it at 1700 miles.Find this very interesting as my 2022 Gen4 Expert 165 Turbo R has 940 miles (1512 km) on the original belt with no issues. Clutches and belt have been cleaned every three or four rides. High Altitude set up with clickers set on #3.
Maybe the extra power of the 2023 is harder on belts, could be clutching or just proper maintenance.
Time will tell.
If you allow the sled to hit the rev limiter as it will from the factory, I can't see how you won't have problems.I see many on the you tube having belt issues also. First year R&D guinea pigs! As the free rider said the quality control has been lacking on the new machines. His 850t ate reeds at 700 km...
I think some of that is pilot err. Had mine start backfiring in wyoming. If you let that happen too much it will take your reeds out.I see many on the you tube having belt issues also. First year R&D guinea pigs! As the free rider said the quality control has been lacking on the new machines. His 850t ate reeds at 700 km...
