A
AZ800
Great info here!!! We actually carry road flares. Those things will start a Fire!!!
Same here. Best firestarter out there and doubles as it's intended purpose, a flare, if needed.
Silky Gomboy (300mm) or Bigboy (340mm) folding saws are amazing. Probably the same blade as the saw mentioned above. I have had a gomboy for 3 years and use it constantly clearing dirtbike trails in summer and its always in my pack in winter. Still cuts like new. these are pull saws and are razor sharp so you really dont need to use much force to cut. Since the main force is applied when pulling the blade never really gets stressed. never broken a blade and I have cut literally hundreds of trees with mine, mostly in the 6" and under range but occasionally up to 12" when there is only one big tree down on a trail and I dont want to haul the chainsaw a long way to cut just one.
These things make pretty much any other portable saw look pretty silly. If I needed firewood in a hurry I wouldnt want much else. You can also reach a lot higher to cut dead branches then with one of those hand chainsaw setups.
No, not necessary if you have the means to stay warm. Personally haven built a sno cave since i was a kid but they work if the conditions are right.This might be a stupid question, but I'm gonna ask anyway.
Is it necessary to build a fire if you have a way to make shelter and get some insulation between your body and the snow? I'm thinking, worst case, a shelter half or tarp and sleeping pad or hammock. Maybe dig a trench to block the wind, tarp to block falling snow...
My thinking here is to have a decent sleeping bag, good gear, (Klim or whatever) ect. instead of going to the effort of building a fire?
Thoughts?
Not only can I run a full lap, I can do it while holding a keystone light!I get ridiculed for carrying most all my survival stuff (food, water, stove, emer. blanket, change of clothes, water, first aid etc) in my backpack, but if my sled slides down a ravine and I bail, I want my stuff with me, not 1000' down there. I'll put up with the extra load on my legs.
Here's a thought to consider relating to exhaustion and the need for a fire vs. holing up. Ask yourself: Could you run one full lap around your high school track - non-stop? If the answer is in doubt, maybe the key to survival is best done by prepping your body now with something other than a Keystone Light.
Thanks for the thread guys! I had quite a bit of stuff already in my survival kit, but after this thread I decided to add to it a bit. This gear is in addition to my tool kit, avalanche gear, etc. All gear is packed in waterproof Seal Line dry bags.
Storm Proof Match Kit
Headlamp
Survival Pocket Chain Saw
Survival Hatchet
24oz Aluminum Cup
Exotac Emergency Candle
SOL Escape Bivvy
Ultra Compactable Sleeping Bag
5X7 Tarp
Waterproof Adventure Medical Kit w/quikclot
100' Parachute Cord
8' Tinfoil (fire liner)
8oz Lighter Fluid
4 – Hand Warmers
2 – 7oz Sternos (fits inside aluminum cup for storage)
Toilet Paper and Hand Wipes
2 – Lighters
Spare Gloves
Spare Socks
Beanie
3 – Freeze Dried Meals
Weighs 10lbs
If I can't survive a couple nights on the mountain with this setup, then I guess it's just natural selection at work!
OK, I have another question for you guys:
Bears are typically hibernating when we are sledding, but what about wolves, Mtn. Lions, or other wildlife?Anybody ever ran into trouble with them staying out overnight? What do you guys carry for self pretection? I see some guys have hatchets. What else?
Why carry lighter fluid when you are riding a sled full of gas? dip a tampon in the gas tank and itll burn just about anything.
Also, instead of 14 oz worth of sternos and a large aluminum cup, might as well carry a Jetboil or MSR Reactor stove, super efficient at melting snow to drink and also will boil enough water for a freeze dried meal in a few minutes. With a small fuel canister Id be willing to bet it weighs a ton less and also will work in very stormy conditions. Also has a built in ignitor so can double as a lighter if you drop the others in the snow and works as a cup/bowl too.
2 reasons why I want to carry lighter fluid. First is, if I'm stranded because I ran out of gas, the tampon is going to be worthless with no way to help. 2nd is if I need to walk out or go for help on foot, I can't hardly take my sled with me. I don't want to count on my sled being right next to me in every emergency full of gas and ready for a tampon.
I'm sure the Jetboil is fantastic (I have a MSR Pocket Rocket for backpacking), but I'm not looking to drop another $100+. I'm contemplating removing the Sterno's, in favor of the Pocket Rocket, but the Sterno's are cheap. I'll have to test them to see how effective they are. Some canister stoves are ineffective below freezing and most will not even work below zero unless the fuel canister is pre-heated by another source first. The Jetboil Jetpower canisters probably work the best in low temperatures with 20-30% propane with the remainder iso-butane, but you do loose effectiveness and burn time when the temperature drops under 0.
Anyone used Sterno's at high altitude and cold temperatures?
Thanks for the feedback.
