Bar Riser Heater? DIY Bag Warmer
4Z
Trying to keep my valuables warm, like camera, phone, batteries etc... Futzing around with the underpowered OEM sack heaters, decided to figure out a way to actually keep things warm. Here is what I did, you can make your own very easily with an OEM connector too
I used a quality bar heater element from Symtec. Got if from Amazon.com clicky. These have a high setting of 20 watts and a a low of about 8 watts. Tested with the low setting and it was "OK" but prefer the high 20 watt. Didn't melt anything but stayed very warm and the heat was dispersed across the plate. Now the plate I used was run of the mill 5052 aluminum and 1/8" thick, which is double what some of the OEM 3 watt heaters use. A very nice heat sink indeed. Used a fiber disc on the edges of the plate for a nice finish, don't like chafing on the sack....
You can upgrade the OEM Ski-doo by soldering on a Radio Shack phono connector (that's what they call it). clicky For the Dragons and Cat (not sure where to get a connector for the Pro), you can use these clicky
You can burn a hole in your sack and feed the wire through, or just let it hang out of your zipper, like I prefer...
I wrapped my HD video camera in a beanie (stocking hat) and it stays warm all day.
sack warmer.jpg sack warmer 2.jpg sack warmer 3.jpg sack warmer 4.jpg sack warmer 8.jpg sack warmer 9.jpg sack warmer 5.jpg
Sorry, I couldn't resist.:face-icon-small-coo
Looks like a good idea. Thanks.
that super trick, i once had the same vision but had a hard time finding my shoes and all the other stuff needed to get things accomplished
  • Like
Reactions: 4Z
I love how you are always thinking and experimenting! Always a fabulous contributor to our community!
  • Like
Reactions: 4Z
Forgot to mention, you can pop the plate out and hold it in your hands if your fingers get cold. Keeps the palms warm.
