Caleb jumped on my buddies sled and buckled his tunnel in 1 move. I think that bumper has something wrong with it. Bad geometry or something ??View attachment 399813View attachment 399814
Cleaned my bumper off today.
Reentry bail.
Straight up in the air came down on a rock outcropping (exposed by the track on the way up)
Guess it’s tunnel cut time.
Only thing I can guess is maybe the raised handle portion puts additional strain on everything if impact is like smf’s. Vs a handle straight/in line with the tunnel.Caleb jumped on my buddies sled and buckled his tunnel in 1 move. I think that bumper has something wrong with it. Bad geometry or something ??![]()
That's what I am thinking. The geometry of the bumper makes its weak on "opening up" towards the sky. Which basically bends the sides of the tunnel out.Only thing I can guess is maybe the raised handle portion puts additional strain on everything if impact is like smf’s. Vs a handle straight/in line with the tunnel.
That said it looks like it kept the rest of the tunnel straight and likely dissipated energy from the rest of the sled
I cleaned a b&m fab bumper off my 2016 axys the same way.Only thing I can guess is maybe the raised handle portion puts additional strain on everything if impact is like smf’s. Vs a handle straight/in line with the tunnel.
Do you like that bag behind the seat?I installed the BM Fab, everything lined up and was smooth.
Anything short of 1 1/2” DOM tubing both sides run forward to the bulkhead would have crumpled.
Definitely not going to be doing that though.
I do like it but not waterproof. I pack my tools in there, holds quite a bit of heavy chit. I have everything in waterproof bag or box so I don’t have to dry chit after riding.Do you like that bag behind the seat?
Had to improvise a little to get mine installed unfortunately. Removed factory bumper and went to install BMP. All original bumper holes lined up perfectly, however holes in tunnel were too big, and Rivets wouldn't hold. Tried larger rivets but they were too long and worried track would rub. Ended up buying stainless and black button head bolts to use in those 6 holes on each side. Also 3rd hole from rear seemed to high and big gap with taper of tunnel so didn't drill that one. Not perfect but It works. Hopefully snow is bumper deep and will never see it!![]()
Just installed the BMP front and rear on my wife's sled and had to improvise a bit as well. The provided rivets weren't long enough so I used some longer ones and added small washers. A few of the handle holes didn't line up well with the holes in the side plates, they took some convincing. The bends of the handle didnt quite match up with the bend on the side pieces and tunnel. Couple of the tunnel holes didn't line up well either. Front was better but I had to fight it a little bit to line it up, also the hood latch pieces they provide are very "rough l" and the quarter turn latches are pretty tough to turn now. Might try shaving them down a little with a Dremel.Had to improvise a little to get mine installed unfortunately. Removed factory bumper and went to install BMP. All original bumper holes lined up perfectly, however holes in tunnel were too big, and Rivets wouldn't hold. Tried larger rivets but they were too long and worried track would rub. Ended up buying stainless and black button head bolts to use in those 6 holes on each side. Also 3rd hole from rear seemed to high and big gap with taper of tunnel so didn't drill that one. Not perfect but It works. Hopefully snow is bumper deep and will never see it!![]()
