M
mxracer299
I just picked up a TKI belt drive for my 18 800 Axys 163. Now that I have unlimited gearing options I was wondering what people are liking for gearing?
Been a lot cheaper to remove the Axys Quick Drive (QD) sprockets and install a set of Pro-Ride QD sprockets using the Axys QD belt.
Try a 24. You might be surprised. It's only a $100 but it might improve the sled like a $1,500 upgrade.
Sent from my SM-G920W8 using Tapatalk
The OP rides trees at 6-9000ft and doesn't care about top speed. The gear that puts him at 1-1 for the majority of his riding is optimim. Low gear benefits-Geared for a top speed of 60mph in overdrive? Probably not advised. TKI doesn't even make a 24t anyways.
MXRacer299, I recommend a 29t or 30t depending on terrain and riding style.
with all the fuss about the QD belt change, the zip tie method, pulley extension etc I was scared as hell to do it myselfIt sure would but I think TKIs belt drive Is far superior. I like being able to change gearing, change belts easy, be able to tension the belt correct and have much more belt engagement on the sprockets. I had to change a belt on the mountain on my 13 pro, I don't want to do that again.
Running at Olav Aaen's 1-1 a majority of the time.
More throttle response.
More belt surface to grip on.
Cooler clutches.
Better backshift.
More speed.
More consistent wfo rpms.
No downside. Don't resist. You know you will have to try it now Tdbaugha. I have a 23 tooth if you want to borrow it. You might have to change the way you clutch and think about clutching. There is a better way.
Credits to the clutcher of that sled tho-best setup I have seen including Burandt's sleds. I could feel the instant throttle/engine/backshift connection when watching the vid.
The results show your effort. You went the extra last 20% to find perfection. Most just get it close enough and call it good. A perfect model of how a sled that is setup should sound!Thank you. That’s the TRS setup tweaked for my conditions and sled. [emoji1417]
