Wondering what opinions are on the x3 track. I have come across one but no experience with the new axys mine came with 2.6 and coming off the cat I really like the claw. need real world opinion's
There's no comparison to the stock 2.6. X3 eats it for lunch and spits it back out.
X3 vs series 7 3"?
you have enough clearance to run it but you'll need new 3" pitch drivers to match the track.
With that said, I ran a 3" pitch track on my stock skidoo for 3 years without issue....
I assume you mean a 3" track on 2.86 drivers.
Thinking about trying this on my pro. Cat 3" drivers measure about the same between teeth as the pro 8 tooth.
My brother has 4 rides on his quick drive axys with stock drivers and the x3.2.
Probably less chance of ratcheting than stock.
So you guys are running 3.0 pitch tracks with the factory 2.86 drivers and its working fine? Eric
Yes.
Skidoo guys have done this for years.
Started running this because the drivers my brother ordered had not showed up yet.
Haven't put the drivers on because the sled works fine as is.
Series 7 will trench more.
Also hook up better on logs, brush, dirt, old tracks, small mammals etc.
At least vs the x3.2.
In the deep (wet or dry) the 3.2 stomps the series 7.
After feeling the soft ish lugs on a x3 i can only assume it will perform closer to the x3.2 than the series 7.
I cut my center lugs on my series 7 to allow flex and it made a noticeable difference in float.
Made a difference you say, how ? Less trenching? More floatation?
This sure will be interesting. Waiting for an answer.?
Yes.
Lol.
It will be interesting to see if this works out in the long run. One reason why I think it worked (a few had issues once the miles starting accumulating) is the fact that BRP has used much better drivers (extrovert) than Polaris and the center driver????? I hope your brother's sled works well. You're correct about the difference between the series 7 and the X3/3.2. My observations are the same.
My recommendation for going with an X3 or 3.2 would be to go with the Avid Power-claw 3.0" drivers, ice age anti stab, and throw the mickey mouse Polaris drivers in the trash.
