JeffBrines
Sled: 2022 Boost - 1,600 miles
Symptoms: Under high load and higher temps, I'm having detonation problems. This problem only appears in this exact situation, which is (unfortunately) when I most need the sled to be there for me. I don't get det in an open field going WFO or similar. Outside temps - 35 degrees and sunny. Sled temps 125.
Catalysts to the problem: The sled did take an impact (nothing structural broke or similar) before this started to happen.
Code: P1391, also saw the mag side spark plug rattle loose from det (so it appears on both sides).
My guess is the wiring harness to the aux injectors got damaged somehow when the sled took its little jar (I put it on its side on a log).
Question - easiest thing to do would be to throw a new harness at it. However, I was wondering if anyone has successfully fixed a harness? If so, what did you do?
I'll pull it apart today.
