Just got done putting a ZBROS 36" Frontend on My 2017 RMK Assault ..
The spindles are way different .. where the lower Ball joint mounts the Horizonal pieces where the bolt goes through is Thicker like .125 and not .100
Also the spindle has about 8 degrees more Caster built into the spindle as a Milling process not just in the mount both seem to mount in the same horizontal plane ..
The arms are mounted with alot thicker bushings and arm mounts or tubing are alot thicker ..
As well as the arms are obviously different ..
All the Ball joints where the spindles mount to arms are identical nothing different there ..
To mount PRO RMK /SKS arms on a ASSAULT RMK you need all of the grooved pins washers and clips with the RMK Bushings .. I believe it's a total of 32 parts ..
The Assault Spindles also have clearance for the Zbros Arms to direct fit with no Grinding or clearanching needed !!!!!!
