N
NytroMTXPete
I received a set of Mountaintech 38" wide 3+ forward A arms with stabilizer bar mounts on Monday. I installed MPI oilite bushings and got everything mounted on the sled. I am extremely impressed with the quality and build design. The ball joints are super heavy duty and make the Yamaha ball joint set up look like a joke. Apparently they are very economical to replace if they ever wear out....unlike a Yamaha ball joint where I paid something like $108 for one from the dealer. Installing them was straight forward like any other A arm. I also received clear and concise instructions....but what guy reads/needs instructions??
While setting up the caster/camber angles a couple of friends of mine dropped by and whipped out their smart phones with these angle apps. Turned out I was getting some whacked out readings that almost made sense, but didn't. I called Mountaintech for some tech support and I was told to get a good old Angle Finder from Princess Auto. I picked up an Angle finder for 10 bucks and got the readings I needed. As for the smart phone, it works great if you have the correct app which the guys didn't have the first time. The correct app is called the Clinometer. It is very accurate to a tenth of a degree. The coolest and most innovative part of this design is being able to adjust caster AND camber quite easily. I have read in sled magazines for many many years about caster and camber angles where manufacturers have played around with it from one year to the next and the spindles have always been fixed in one position. Now one can set the spindles up the way they want. Recommended settings for the Nytro are 23 degrees caster and -1 to -2 degrees camber. My subframe may be slightly tweaked so I can compensate and still get the 23 degree caster sweet spot.
I removed my JRE spindles and put on my stock 08 spindles to really be able to gauge an opinion on how the A arms will affect the sled. My 08 MTX came with a stabilizer bar and I recall many people taking it off completely (mainly true mountain riders). I never wanted to take mine off because my riding is on lakes and bush trails and when I play in the powder in swamps and climbing hydrolines I disconnect the swaybar. So, I am happy I have the option of being able to utilize a swaybar on actual mountain/narrow A arms.
I am taking the rest of the week off to really put these to the test. Tomorrow I will be doing the initial spindle settings and getting all the plastics back on. I will go for a shakedown run and make sure my install holds together. Then I will be taking off to camp with lots of gas for 3 days. They are calling for another snowstorm tomorrow. It was -30C again this morning. The snow is very deep and winter is still going on strong!
I will keep everyone posted.
