Just listened to the hour and twenty minute long SW podcast on spotify. Here are the main points:
- Tested all 154 length tracks. Some 3" lug and one 2.6" lug. 3" was the definite choice in the deep snow they were in. 2.6" trenched a little more.
- SW staff does not like the current Alpha Ascender. Like at all compared to a Polaris or Ski-Doo. Catalyst feels nothing like the current platform. It's lighter, more balanced, predictable, and the Alpha skid in this new chassis doesn't feel like the Alpha in the current chassis. They had one current 800 Alpha and no one wanted to ride it after being on the Catalyst.
- Does not feel like a Cat. Feels like something completely different. Feels like the most naturally adapted mountain platform of any brand. Cat staff emphasized that mountain was given the priority when developing the platform.
- Chassis feels shorter and smaller.
- Everything is packaged about as tight as it can get.
- Reduction of parts throughout. Even smaller, trimmer wiring harness.
- Weight.
- They believe the 10% weight reduction.
- Sleds they tested all had ES and they can't believe they didn't notice the extra weight from it. No different tank or seat for ES models, but rest of ES system is largely the same as past Cat models.
- There is no "breakover point" in handling. It's an even feeling rolling from one side to another and easy to compensate or make changes.
- Back end never washed out.
- Belt drive.
- 3 gear ratios available that use same belt.
- Eccentric tension adjustment on the top shaft.
- Steering system.
- Old system uses 6-7 parts from handlebars to skis.
- New system uses 3-4
- New mountain steering post has a U-joint in it to get it vertical.
- Steering is easier and progressive.
- Aluminum accessory running boards that were on the white/blue sled iced up. Composite boards did not ice up.
- 600 Engine
- It rips.
- 125hp class.
- In the Catalyst chassis it goes as good as an 800 in another chassis. They would rather buy a 600 Catalyst than an 800 Ascender.
- Will be no larger motor in this chassis for 2024. Cat simply does not have it ready, supply chain, manpower, etc.
- They are excited for when the larger engine comes.
- Limits on how many snowmobiles can be built.
- Cat is going to try to price it around current 600 prices.
- Everything was better than expected.
They removed the snow flap so I doubt its more cooling than beforeas some of us have to ride more than a few miles to get to the good stuff, and have to leave scratchers down while on the trail, and sometimes the trail is so hard even they won't keep the overheat light from coming on.....i read somewhere that there is improved cooling....any imput as to what that might be, and is it significant
My only guess is the one piece tunnel design that is straight intead of "stink bug rear" so any snow on the track gets thrown directly to the front area but idk im not an engineer.as some of us have to ride more than a few miles to get to the good stuff, and have to leave scratchers down while on the trail, and sometimes the trail is so hard even they won't keep the overheat light from coming on.....i read somewhere that there is improved cooling....any imput as to what that might be, and is it significant
IMPROVED COOLINGas some of us have to ride more than a few miles to get to the good stuff, and have to leave scratchers down while on the trail, and sometimes the trail is so hard even they won't keep the overheat light from coming on.....i read somewhere that there is improved cooling....any imput as to what that might be, and is it significant
Should easily get 7mo of use out of both of those.A snowmobile used for 4-5 months is still a better deal than a boat that can only be used for 4-5 months!
hellodear.in
teatv
They will release more info before/at snowcheck… will probably be terrible and confusing information if it’s anything like previous years info, but there will be more.Wondering about these dates they talked about in the beginning of the thread. Doesn’t seem like much more info has come out on the current 600 they plan to release in march for pre order. I’d like to know what I’m ordering in detail before I order one.
