Apex help
Boosted Brad
I have a buddie with a 07 Mcx apex it starts and warms up till light goes out and then dies and won't run till it is cold again . Any ideas why thanks brad
my sled, when i forgot to connect boost gauge, i started it up, there was a code, i couldnt get it to idle at all, i had to open the throttle up to get it to idle, and it was rough and trying to die.... of course fix the vacuum leak, as in the "oh crap forgot boost gauge..." and idles and runs like a champ
Spudders and runs bad then dies and won't start till it cools down ie1hour clears all the old codes and checked spark seems week to me thanks for the ideas
apex
spark plugs are fowled out change them and his sled will run..ive done that a couple times before.most the time its from starting the sled and reving it up then shutting it off and doing it again. that is usually is the cause for this.
New plugs but when checking the spark it looks a little weak good compression uuug trying thing off my sled on his and same thing !!?? Thanks brad this is a weird one!!!!
Mine did the same on a vacuum leak....run till red light went out the die....pressure test the system.
Lol. Thats what just happened to mine. Would start then after a while it just died. I removed intercooler and the secondaries are firing at idle. I believe the box is baked ! Oh well that is 14,000kms. Lasted a while. I guess i will have to retrofit a newer box and keep riding until i hit 20,000km, then Thistledoo can pay me that hundy he bet me LOL !
