E
Extreme-One
Couple questions on replacing bearings on my Apex, it has 6500 miles with Turbo and been running strong but I thought I should go through the chain case and jack/drive shafts bearings.
Are there any other sources for bearings other then Yamaha? I've found bearings for other sleds for half the price of factory, figured same for Yamaha.
How do you remove the clutch side bearing on the jack shaft? Looks like there is some kind of nut on the inside. Not sure if you need a special tool or a trick to remove it.
Thanks for the help.
