B
briand
No i don't think i will pull the 73-65 in the mountains but when i purchased my team tied i told them what i was running with the TS 98 which was a 66-44.46 with the Black purple 160-240 team spring with 66 grams Polaris weights or the 68 grams MTX weights with 3 grams added in the mid hole for 6000 to 8000 ft and it pulled this flawless. Great acceleration and great back shift. They crossed it over to a 75-65.46 & 75-63.46 helix. Now when i purchased it they did not have the 75-65.46 but had a 73-65.46 & 73-63.46 so i bought it to try.
Now my sled is a 03 800 vertical edge with
SLP single pipe,
Thing can,
SLP big air horn kit with 2 flo rites in the dash,
Engine rpm run best at 7950-8000.
162" X 2.5"X 15" 3" pitch track 8 tooth avid 3" drivers with drop and roll.
19-43 gearing.
Rails are flatten no tip up at the rear and this made a big difference too.
I found with this big track and flatten rails you could pull 4 more degrees with no trouble. A lot more track flat on the ground at all times. Its similar to riding in soft snow and on harder snow pack I can usually pull a little more weight or helix when it is harder pack snow then in soft snow.
I fairly confident i can pull the 73-63.46 up high but i guess in time we will see.
SLP single pipe,
Thing can,
19-43 gearing.
