M
M1000Mod162
Its the cr setting that u want to adjust. U need to be in advanced mode to adjust it & make sure u only adjust the cr setting or it can mess up the tuning. I am on my smart phone now so searching the forum is a little tedious 4 me. The cr number divided by 4.5 is the boost pressure that the secondaries come on at. If cr=30 they come on at about 6.7 psi. I assume you would want a number around 23 (5psi) and then increase it slowly until it doesn't bog... but I personally wouldn't go past 28 unless someone tells u that is ok for an m1000.
I couldnt find it in advanced mode however I did find a cr number in the supertuner mode and it was at 21 so im guessing that could be the problem? I dont quite understand how that would cause a problem having them come on too soon though? Can someone please explain this to me a little more? I will def play with it a little next time out just not understanding how it will make difference?!(Should note secondary inj are in throttle bodies!)
