put the puller in and tighten it good then slightly hit it with a 4lb hammer...(a good few taps) then tighten the puller more until it pops right off!! itll come just keep cranking on it
dont be scared to crank on it
You should not tap on anything while removing the clutch.
Can you imagine what happens to the ball bearings on your crank when you tap the end of your puller? All this force is transferred into your crank which then tries to "move" it through the crankcase to the mag side.
It should not be necessary to hit it anyway, use a little grease on the end and on the threads and apply a little heat to the steel center of the clucth, beetween the sheaves....like mentioned above.
A little patience is a good thing when dealing with this procedure to.
