i got a 2012 pro and wanting to take the clutch off to do some clutch work on it and i have a polaris clutch puller for the sled and its not comming off. anyone have any input?
put a squeeze or two of grease into the clutch bolt hole. Grease the threads on the puller.
Just using a puller alone dry and without grease or water etc... won't be near as effective.
For what it is worth, I now clean the sheaves, change weights and springs w/o taking the clutch off. Just easier than torqueing on my crank.
Bunker Hill clutch tool, aka dummy clutch tool ( Wahl bro racing), I've been using one for years, works great!You just gave me an idea, and I'm sure that this isn't a new idea. Getting a cover back on is a pita. Why hasn't somebody made a stud that you can thread in the clutch, then thread on another retainer nut to hold the cover and allow you to remove the cover bolts and then loosen the retainer? This would make it so much easier than trying to force the cover on and trying to get the cover bolts started at the same time.
I think that I am gonna make a tool like this after I get back from my trip.
Avoid it if you can. But I guarantee there are dealers out there that do use impact guns.A lot of good info here.
Is using an impact wrench to remove the primary a problem??![]()
put the puller in and tighten it good then slightly hit it with a 4lb hammer...(a good few taps) then tighten the puller more until it pops right off!! itll come just keep cranking on it
dont be scared to crank on it
