any idea where a guy should put an extra mini flow vent?
K
killerrf
i ordered fastlane side vents and two mini vents... i thought i could use two mini's but i cant find no where to put the second one... i put the first one on the clutch side. there is enough room to put two on the clutch side but i dont know.
on the clutch side keep it above the belt guard. I've seen blown belts wipe out vents and then you are left with a hole for snow to come in. The belt guard has vent slots in it so it will still let cool air get to the clutches.
yeah thats what i did for that side. holes i cut are parallel to the openings in the clutch guard so air should be able to flow thru guard and over clutches.
