whats all this "hose block off" "selinoid" mumbo-jumbo you guys are talkin about?this mod looks like something i wanna do! but i feel kinda lost here!
I thought I would mention since it came up that I am also running stock valve springs with my plugged VES hose mod with good results. With my loud mbrp can I can hear quite clearly that it runs with true variable exhaust valves instead of the light switch stock setup. More lower midrange response was my gain from this free trick.
I forget again, what springs do you run when plugged?
I wish I could remember what I put in mine...Wanna swing by my house and check?
Are you guys opening up the feed by 10 or 20% ??
Your valves may be opening too early now, easiest solution would be to install stiffer VES springs, or in a pinch I'm sure one could shim the spring a little somehow.
