M
MOSKIDOO
HARD PULL FLOAT
After reading all these posts and owning a firts gen FLOAT 30 I wonder one thing. It seems so simple but could be some of the problems noted. I have test fired my pack and it was real easy to pull the handle I thought, but before I had ever test fired it I had heard about this problem and gave my pack a "once over". I noticed something that could cause a "hard pull". Where the cable comes down through the shoulder strap it runs through a small loop. I made sure my cable (covered part) was all the way through this loop and have since used a small zip tie to secure it there. If the covered part of the cable was on the top side of the loop and the bare cable running throught the loop I could see how the exposed part of the cable and its outer cover could catch on this loop when you pull on the handle. This would create a "hard pull" due to the fact that when you are pulling on the handle it is pulling on the entire cable catching on the loop and not letting the cable inside pull through the outer cover thus releasing the pin. I may try my pack again tomorrow with the cable loose in the strap and see if I notice a difference. To me the cable should be secured at the point of the handle.
