Alternative Impact 36" kit, Kmod skid - on turbo poo
Just got back from 1st run with Dan 36" kit on my pro
Install - Dans directions were spot on - easy install, fit and finish was great.
Set up exactly like Dans instructions - love that the sway bar is still mounted. NO conflict with shocks, full turn radius throughout the arc, and no grinding on the spindles.
Makes tipping the sled up substantially easier - Im 150lbs soaking wet and had some issues last year - this kit makes life easier -
As per stability - I had no issues on the trail - I could bomb down the trail with my buddies, just as fast and take any corners not worrying aout the ski stance.
THANKS DAN - LOVE IT.
I also installed the full KMOD skid, c/w raptors - Thanks to Kevin - spot on dialing in of the shocks and system - within a click or 2 over the phone. The skid is awesome - we took pokes in the steep n deep - moving over each time, and changing the quick adjust - and noted substantial change each time - great ski lift control - sure makes it hook up.
This kit holds the turbo poo to the snow - Looks great and functions as good as it looks...
Highly recommend.
