Alpha with Attitude
niner
649
717
93
Lacombe Alberta
[/IMG]
Just a few pics of my Alpha that I built with Altitude Power Sports. So far we have done the SSI titanium can, SSI Y-pipe, SSI clutching, BDX running boards and front bumper, Backwoods BMP rear bumper, BDX chaincase cover and the billet BDX front end. We did a full wrap with gloss black to cover up all the matte black. Sled looks great and works even better.
Matte Murder
3,579
2,259
Looks great! For the first time yesterday I got the bog from burying the exhaust exit in the snow, heavy wet spring snow. Never had it in the pow tho. Do you have the buried exhaust bog it’s that can. How loud is it?
niner
649
717
93
Lacombe Alberta
I’ve never had a bog with this setup. The titanium can has a nice rumble, it is not loud.
J
Feb 24, 2019
7
-1
1
[/IMG]
I want info on your snow flap????
TNTCOPP
2,163
380
83
53
Buckley, WA
his seem to be all nice and bevelled trimmmed
I dunno - maybe he'll chime in. maybe it's trimmed a little to go around the tail light. Other than that , looks like maybe 4 screws and boom it's done. I have a few of those bottoms lying in the shop as I always cut them off!
A
ak
2,776
723
Take the stock flap off and put one off a Polaris axys are pro rmk. It fits like a glove.
niner
649
717
93
Lacombe Alberta
Yes it’s just the junk stock flap cut and trimmed to fit. We call it the Alpha Expert flap. Never had any trouble overheating with it last trip we had 28 km of groomed trail and never went over 125F. With scratchers down.
turboless terry
5,569
6,771
Big Timber, MT
Don't get the 3 inch track flap. It has a scoop and doesn't work. The alpha tunnel is way shorter than a polaris. The replacement cat flaps aren't as hard as the original that I broke off. They must have screwed up on the durometer on the original ones.
niner
649
717
93
Lacombe Alberta
[/IMG]
Seeing I already had the BDX front end which raised the front end 3/4” I thought I should finish the job and raise the back of the sled also. I didn’t want to drill another hole in the tunnel to drop the skid so I went another route. Was more work but I think it will prove to be a better way. Going to do some more testing before I give away to many secrets but so far happy with the results. Will try to get a stock Alpha and another pic comparing this set up.
sno*jet
2,829
1,299
looks like a longer limiter strap and lower rear hole was used.
didn't know the box front end was 3/4" higher. thanks might look into that.
niner
649
717
93
Lacombe Alberta
Correct on the longer limiter strap, but you only gain 3/8” of height with the strap. To get another 1/2” of height you need to relocate the shock mount.
[/IMG]
ullose272
3,372
963
boise idaho
[/IMG]
Looks like you made the shock more up and down to make it taller? Couple potential issue that could come from this. First is the shock will act stiffer because it will be going through its stroke faster. And second the shock could bottom out before the rail bumpers causing mount breaking. Just couple things to watch
Sent from my Pixel 3 using Tapatalk
