I Guess I’m that one unlucky guy this year. Have 170 miles on my silber alpha and it just won’t run above 7000 rpm. It actually stutters so bad as it goes above 7000 that it feels like the track is ratcheting Of course I didn’t ride it stock so I don’t know if it’s a cat problem. Starts great. Idles fine. Plugs are new. Properly gapped and colour is good. Wash is good Both primary and secondary clutches are shifting out. I have the new program. I have checked and double checked exhaust valve cables. Valves function at start up and function at rpm Have double checked all plug connections. All plumbing is air tight all exhaust gaskets are double Spring and no leaks. Throttle cable is set Turbo spins freely and spools. Compression is 123 both sides. I’m just stumped on this one. Thinking about going back to stock to see if it runs. anyone run into something like this before
Had a friend who bought a Silber kit this year for his alpha and had the same problem. Ended up having a **** ton of packing material jammed in his compressor housing. I know it sounds crazy, but he had the exact same symptoms you explained. Check out the pic of his housing. Very little air getting g past that. Probably worth looking into.
