Alpha elevate reviews
With the skid installed, both mounts dropped and the additional longer limiter strap your suspension should be sitting dead level on the floor. We designed to kit to have a very neutral balance and for it to sit completely level on the shop floor. This is configured with all shocks at full extension, no sag in them.
We are working on some additional recommendations on setup as the new models and shock packages have significantly different preload/sag based on model.
My 165 ,the back of the track doesn't touch the ground. The sled is supported by the front. Been this way since day one. The longer limiter strap just lets the front come down more. Maybe mine is an anomaly? The only way I can get the back of the track to touch the ground is if I let all of the air out of the front shock.
The rear only needs to come down ~1/2"
Or front up 1/2".
The elevate with dropped skid is better than stock But still not flat like it should be.
All the weight is supported by ~16in of the rail...
Sent it
Ah I gotcha. I believe that is intentional from cat to make the longer sled feel more like a shorty but perform like a longer. Similar to how doo rails curve up in the back.
This is the only pic i have. It's before elevate install. U can see how far the track is above the concrete at the bump stomp. Twice as high at the rear. The elevate spindles and dropping the skid helped but still not level. 75psi in skis, 70psi in FTS, 145 in RTS. I won't run the FTS less than 65psi, it hits the rail to easy.
Now i moved the front of the skid back up to stock and pumped shock to 85psi. It looks level. The limiter strap may need to be a bit longer as the one in my kit was nearly identical to my stock strap. I gained at most 1/16" in height.
Sent it
It almost just looks like your front limiter strap stretched and is allowing the FTS to drop the front of the skid.
would be easy to compare with a buddy's sled
It's been like this since day one.
I noticed it on the trailer.
Sent it
Why arent you using the iceage bumpstop
Sent from my Pixel 3 using Tapatalk
Pic is from 2018 when sled was new. (Maybe early 2019)
Can't take a pic of the goofiness that is, cause i moved the front back to the stock location, left the rear in the bottom. And now it sits as flat as my 14 next to it.
Sent it
I will ride tomorrow and report back.
I may swap the suspension up on the hill. But if we have 3ft of new, i may not? Depends on how the sled handles.
If it is total crap, i will not ride it all day like that.
Sent it
So far i am very happy with the results.
I am going to put a longer limiter strap on to get a bit more ski lift.
Rode in 2ft+ so i need different conditions before i say i love it.
Sent it
Sent it
What are you liking about it
@ullose272
I didn't seem to have near the trouble on the ice but i didn't stop either.
Sled didn't fall over when i would try to get on it. Lol
Seems to be more stable yet still flickable. Sidehilling and carving in the neutral position.
How my sled handled yesterday Is how i want my sled to handle. This is what i expected from the elevate kit.
My rail is parallel to the ground like it should be.
Sent it
Stock limiter and Elevate limiter.
Elevate spindles, Front of the suspension in factory hole and rear dropped.
I loosened the limiter one hole. Front of the rail is still supporting the weight of the sled. U can see the paddles bending.
Rear is off the ground.
I assume you rode it both ways and you prefer it like this? Do you have to do anything besides switching holes? Does it affect your track tension at all?
Are you left handed? Do you have anger issues? Looks like you may have punched a few objects in the past. Broken knuckles. Haha
Track was very loose after moving the front back up.
I have 4-5 rides setup as Ice-Age instructed, 1 ride with the front moved up.
Avg 40miles per ride.
Snow was quit deep yesterday compared to the previous trips but i was very happy with the handling.
I loosened the limiter strap today in hopes to provide a little more lift under throttle and ease up the steering a touch, i haven't ridden yet. I like wheelies and its a 165......
Sent it
Sent it
Are you stock besides the elevate kit? I wish I could give and honest review of mine. If I had to describe it out of control would be the best description. It wheelies everywhere tips over with the slightest pressure and climbing hills with the skis in the air is like flying a kite in to much wind. These are all good things it’s just been way more of an adjustment than I anticipated. I didn’t ride today next time out will be next weekend and we’ve got enough snow now to feel comfortable riding around.
Stock other than elevate. Stock it was wild for sure and that's why i went with the elevate kit, seemed like it would put some control back into the sled. Yesterday it felt more like a lifted twin rail with the traction of an Alpha.
Sent it
Hey summ8rmk: Do me a favor and measure the distance from the top of your tunnel to the center of that front arm mount bolt. While you're at it, see what the bottom one is too.
I'm curious how that compares to the 2016 and previous arm mounts.
Thanks man!
