P
pura vida
The motor would be knock against the straps. Have you seen an increase in belt wear in say the past 100 or 200 miles? We couldnt figure it out til it got bad enough that when we would pry on the motor it would move around more that we thought it should. Then when Chris got home he found a bolt in the bottom of the belly pan. Then the search for where it came from began. You know the rest of the story... Hope that is all yours is. Better yet if you can get it warrentied!
ahhhh, had not considered that. thanks ultrarider, i'm betting that is exactly what my issue is now that you have described it. i also found a random bolt lying under my clutches after a ride. couldn't figure out where it came from, looked real similar to one of the four bolts that hold the skid in, but obviously it wasn't one of those. then the noise started, or might have started a little that same day. now it has gotten worse. probably b/c the rest of the strap bolts are loose. yeah, i bet the straps are wasted now too. definitely will be a warranty item and i'm sure my dealer (hpp for those of you in ak) will take care of it. but how long will i be without a sled? snow is epic right now, and i bet i miss a bunch of it. if i just get the parts from them and do it myself i bet i'm riding much sooner.
pv
