What fittings do you have?I have an airpro on my YZ and Im not the least bit worried about it getting snagged. It is tucked out of the way well enough It would have to be just perfect for a branch to catch it.
So I got a response from airpro saying the Yamaha kits come like this. Doesn't make sense to me as the airlines sticking straight up is just asking for trouble..not impressed and why are yamaha different?
Sent from my SM-G930W8 using Tapatalk
Must watch
Before you all run out and pay exactly 10 x the price for this $10 commercially available valve check this out first:
https://www.princessauto.com/en/detail/2-pc-1-8-in-npt-air-tank-valves/A-p0430253e
Also available at Home Depot in the US (but not Canada - as usual) Just drill and tap your fork cap out to 1/8-NPT and screw this in to each cap and it's the same thing as the $100 unit. I'm making a manifold in the middle with a little gauge which will branch out to both caps so that I can purge in the summer and charge for snow biking with just one point so that both fork legs are at the same pressure.
Not sure what you've got for forks but those are 1/8 npt (nominal pipe thickness/national pipe thread) they are not 1/8 inch fittings. You would need to drill and tap your $2k forks. The bleed holes on my forks are 4mm with fine metric threads.And before you run out and pay $10 for this valve, please know I just ordered a pair from acklands for $3.28 all in. Thanks! ( I do get a discount )
And you found these fittings somewhere?You would not put these directly into our fork caps. Instead, make a simple manifold with two fittings and tubing branching out to each leg. Then only one of these valves goes on the manifold and you pump both forks at the same time...just like the air pro set up.
I didn't mean to come across the wrong way just curious is all. And I get it's just the cap but most guys won't want to take the forks apart to do it. Assuming you'd do this so you don't get any metal shavings inside the fork or can you just remove the cap in place?I bought basically the same at fleet farm for $1.78 each. Drilled and tapped the fork caps and installed them. Really was not a big deal at all to modify it’s just the small cap not a $2k pair of forks! Besides it’s no different than what was there functionally and I don’t plan on removing them ever
Ok cool I just thought maybe Misha found some fittings.Basically I removed the inner fitting. On my 16 WR450F it is drilled to the side at the bottom with a tiny hole. I put a dab of grease in the bottom and warped in a round of tape. Put cap back in and drilled, tapped, and had to use a sanding drum to add a little room to the cap. Blew it off good and removed, blew out from bottom and cleaned with solvent and reinstalled to finish. I can’t imagine I got any shavings in the fork but if it did I guess I will clean them next time it’s apart for seals and oil change not too big a deal IMO
