Which Speedwerx pipe do you run? For low elevation Kelsey recommends the AC925S-M-2 0-5000 feet pipe. The list price for this pipe does include the y-pipe. You can not run this y-pipe as stated earlier. Get just the pipe. Kelsey recommends running D&D's 700 y-pipe for low elevation and the stock y-pipe for higher elevations. He also recommended the Skins Super Q can for the low altitude. If you have a bog it could be your boondocker numbers you are using. Where is your bog at? Just because you have a bog it could be a rich bog or a lean bog.
I just got off the phone with Speedwerx and they say that there are alot of their customers with other 800 big bore kits running their 925 pipe. When I mentioned that on their website the AC925S-M-2 pipe says "5000 FT + ONLY" he said that I would need the AC925S-M pipe for my M7/8 big bore for 0-5000 FT. He also said that they make a Y pipe for this set-up and this part no. is AC800Y-2. I'm confused, since Kelsey told me AC925S-M-2 pipe was the one to get.
Anybody know for sure which pipe to run at low altitude?
