I like the bolts. Did those come with it or did you buy those seperate?Light weight!
Sent from my Pixel 3 using Tapatalk
Im wondering if a rebalance is needed with these covers, or just say F it and run it. The zrp looks nice. Better grade aluminum over the bmp
Bought them separateI like the bolts. Did those come with it or did you buy those seperate?
Joey, you know better. In no way should the cover EVER be preventing full shift out. If it’s to prevent too much tension on the belt at full shift out, the belt is too short or the clutches are incorrectly designed.
If you are building covers that hit the spider nut before full shift out, you are opening up yourself for liability. I have seen a pic of a BMP cover that has come apart.
The Cat cover/bushing contacting the spider nut to prevent full shift out design is both incorrect and dangerous. Clutches use sheave to sheave contact to adjust for full shift out width, not the cover. If Team is using the cover to prevent full shift, they should have manufactured the clutch different.
Under normal circumstances, your cover may be just fine. When you factor in the Team built in cover interference, mix in a little harmonics and very few covers stand a chance. If it were me, I wouldn’t supply any roller bearing type Alpha Cat primary clutch parts for a 2017, 18 or 19. Maybe the 2020’s after the clutches are proven to last.
I’m shocked that you are not aware of this issue. I’d more expect a convicted criminal the likes of E.L. of old Bikeman to deny an issue to make sales, not you.
I have no affiliation with Thunder clutching but I did install the 911 cover on my Alpha. There is no interference and the clutch will hit full shift out.
The pics are the end result of using a cover to prevent full shift out. It flexes on each full shift attempt and will eventually spit out fatigued pieces if not fully fail. A clutch exploding at 8000rpm is the same as Russian Roulette. I’ve had a clutch explode and I honestly felt like I cheated death. I love Cat but this is some serious chit.
Don’t shoot the messenger. I’m simply demonstrating common sense and real life pictures. The above are my beliefs.
I love your vids and contribution to the site. Please keep up the good work. Cheers
Lower the gearing will improve responsiveness. Unfortunately, there’s not a lot of gearing options available.Kanedog, do you have a suggestion on what will lighten the clutch for responsiveness without sacrificing strength or durability?
Quicker rpm response means quicker shifting too, no?
This cracked while i was removing the cover, not from towers flexing. New clutch with 100miles.
I was putting the ZRP cover on while on the hill. I wanted to test side x side on the same hill , same day vs stock cover (rpm).Whoa!!
I’ve got a new clutch waiting to be installed and a ZRP ready for when the clutch goes on.
Summit8k said it pretty good. Rotational weight helps consistent rpm and in some cases, et(drag racing) will increase a tiny bit.Meaning rotational weight actually helps responsiveness?
My ZRP lightweight cover cracked
