I'm not the original buyer, but Ill contact you, email is the best from your website?Please contact us and we will make it right it's actually guaranteed.
Sent from my VOG-L04 using Tapatalk
This cracked while i was removing the cover, not from towers flexing. New clutch with 100miles.
Sorry for any confusion. I should have circled the piece in the original pic.Summit, what did you end up doing with this? Inquiring minds!
Was only the cover affected? Can’t really tell in the pic if the tower cracked also.
Oh my. What model, year and mileage?Kanedog,
It was on a poo
Great info here. Thanks.
To make the engine more responsive by reducing clutch weight you have to make a significant weight change (more than a simple reduction to the cover) as you have to compare that reduction to the overall weight of the entire crank shaft and everything connected, i.e. flywheel, crank pins, pistons, piston pins, piston rods, crank pins, ring gear. Many of these components are made of steel. The other consideration is the rotational inertia energy loss mostly goes away after the engine rpm hits the shift point because the engine for the most part stops accelerating. No acceleration, no losses. So your effort to make the engine more responsive only comes into play during the first second or two after you hit the throttle. It may be worth it if your constantly on/off the gas playing in the trees but otherwise IMO not worth it. When Polaris introduced the Axis RMK in ~2016 they re-designed and lightened the entire crank assembly from the previous Pro RMK. That was a game changer. The CTEC 2 not so much. Don't get me wrong I love my new M-8000. I changed from Polaris for the handling not the engine response.Agreed, but I will say, I think there is still more to discuss. I feel we have a few experts questioning if there is ANY value in lightening our clutches, let alone if there are long-term negative effects, while a couple manufacturers are staking claims it SHOULD be done and buy their product.
I would add (reinforce) that the clutch should be balanced. I wouldn't run an aftermarket cover again without balancing the whole assembly. I failed to do this. Don't be like me.
Couldn't agree more...I don't think the aftermarket cover is going to save them. They are cracking everywhere on the clutch. The cover is just one of the problems. Cannot believe there isn't a recall. They are a huge safety risk.
