I can't believe grown men care what color their sleds are. All about performance for me, I don't care if is bright pink. Whatever sled works best is what I'll ride, for my style that's an alpha setup. I have a 2019 hardcore that I alpha swapped and the only time the twin rail goes back in is for hill climb racing.
First pull pressurizes the fuel rail, never heard of a ecu going to sleep.The initial start of the first pull is powering up the ECU. Cold starts are a little easier with a quick short pull to "power up" the ECU. Then give a solid second pull.
I don't have much chassis input. I can give a little feedback on the 800 motors riding lower elevations.
Have a '16, 18, '19 and a 2020. Also ran a couple of '17 sleds in the mix alongside the first CTec motors. The skid is the same in all the machines. Everything is over 150 hours of engine time.
The old Zuke motors do pull more on top rpms. If you ride maxed out all day you will see the difference. The CTec pulls a whole lot more in mid through just before the top. We usually hop on the CTec sleds when there is a choice. The Zuke gets selected for a top end drag race. It just pulls longer with good conditions.
I still remember the first ride with the CTec motor. I actually giggled in the helmet. The midrange power difference is pretty amazing.
Motor durability has been all over the board. The Zukes were usually solid. Didn't see much initial skuffing and most just kept running. (Had two of the '17 motors go down right around 70 hours). The rest were fine.
CTec motors have been pretty good too. Have not done anything to the '18 or the 2020 sleds. The '19 went down at about 70 hours. The replacement motor skuffed quick, but held compression. It has gone another 80 hours without any big change.
Riding with the motors.
The CTecs are just more fun. The pull is addictive. They are louder when you get into the valves vs. the Zuke. The '20 motor does have that annoying low-mid rpm rattle. It also has a different sound as you crank through the rpms. Almost like a growl. It has a teeny tiny edge on power in that range too. The '18 and '19 have about the same edge over the '20 toward the top. Honestly, most of the time you would never be able to tell the difference, it might be a couple mph.
Oil consumption isn't a whole lot different. Oddly, the 2020 uses more oil than the '18 and '19 motor. Oil range is greatly reduced on the CTec sleds because of the oil pump location. Not a big deal, but the light starts flashing so dang early.
Fuel consumption. Bury the throttle, and they get close to the Zuke. Baby the throttle and they start to sip fuel. You can limp the CTecs a long time too. The Zukes use more fuel on baby throttle. Not a huge deal unless you are running out all the time. Odd note to fuel is the '20 is using more than the '18 and '19 if riding midrange rpm a lot of the day.
Again, I don't have much input for chassis. I can answer more questions about the motors.
It is a mountain sled. It's the ride that sucks that i complain about. It is not stellar on corners. Mine is all the way narrow. I accept that. 10 times worse on trail and 20 times more fun off trail. I ride everything so i know how it compares.Also those who complain about trail manners, Its a frigging mountain sled. I can still rip the trail decently and it corners good enough before a ski will lift. It is what it is and I find it foolish to make it a point on why they didn't buy one. Go buy a 42"+ trail sled then if you want to rip the corners.
I thought the '19 alpha was a sharp looking sled. That and the black and green '18 mtn cat are probably my favorites
My '20 mtn cat is my first 165" sled and first e start and I've got no complaints on either of those options. It'll turn tighter than any of my previous 153" sleds and the track hooks up good enough I still have problems keeping the front end down from time to time. I don't think I'd go back to a non estart sled after having it. It doesn't seem like much, but You'd be surprised how much energy you save throughout the day not pulling the rope. Not to mention how nice it is to start in precarious positions. As to running, it runs decent overall but does have a slight hesitation from time to time when on and off the throttle. I don't know if I was just expecting to much after hearing all the ctec praise on the 18-19 sleds, but honestly I don't think it's anything special over my previous Suzuki power wise. My brothers '14 with just a y-pipe and mds weights will pull away from it in an uphill drag. I'm also one of the ones that couldn't get the mds weights to work, Steve had no idea what was going on either at the time, but that was early season so maybe he's figured something out by now. I hung on to them because I'm wondering if maybe I got one of the super rich sleds I've read about and might get an aftermarket flash next season once warranty is up. 600 miles and only thing damaged was the cross brace at the bottom of the upper steering post from wheelying over backwards on a climb in low snow, covered by warranty. Rear suspension and rail look great.
So to summarize on my '20 mtn cat 165",
handling and traction: awesome
Power: not bad but nothing special
Durability: great
Sorry for the storybook.
It's always bounced between 78ish-8100. I've felt all season like there was something not right but could never find anything obviously wrong. Even had the dealer plug it in mid season and scan it but he said everything looked fine. It feels great on bottom end, but I feel like there should be more on top end. I also noticed it seems to use about a gallon of gas more per ride than my brothers '14 and we're similar size with similar riding techniques. I figure I just got one of the extra rich ones I've heard people complain about this season, and figure I'll do an aftermarket flash after warranty is up. Unless you got any ideas.What’re you hitting for RPM? My 20 walks over my old 14 that had a belt drive, 3” and built clutches. Not even close. If you’re getting beat by a 14 in a climb, you’ve got issues
