adjustable clutch
if your referring to the clickers you can change the clicker # for more or less rpm.
on the primary clutch ther r 3 bolts with a line on them and #s are in the casting,1/2/3/4/5/6.what #in it pointed at know?each # on the clicker is average 200 rpms.
clicker 3 and it holds 8200 rpm if you put it on #4 it should go up to 8400 ruffly.up is up down is down
PS (lossen the nut just enough to turn the bolt).if you take it all the way then you make a trip to the dealer and buy a manual on how to disassemble and re assem.
guik clickers are a slick alt,quick and easy.contact W. B.
