A
AK IQ Pilot
So lets take a look at this in a little more detail. At first lets assume that 2 stroke oil does not burn and every bit of oil added to the fuel is displacing a combustible liquid with a noncombustible liquid.
10 gallons of fuel is 1280oz.
Add 13oz of oil to 10 gallons of fuel and you're premixing at about 100:1.
Add 26oz of oil to 10 gallons of fuel and you're premixing at about 50:1
Add 52oz of oil to 10 gallons of fuel and you're premixing at about 25:1
So if you ad 52oz of oil into 10 gallons of fuel you have a 25:1 fuel
il ratio. This means about 4% of the mixture is oil and 96% of the mixture is gasoline.
So 26oz of oil into 10 gallons of fuel means you have displaced 2% of the gasoline with 2 stroke oil.
Now lets look at fuel delivery and Main Jet sizes. If you start with a 500 main jet and drop down to a 490 you have reduced the main jet by 2%.
So if 2 stroke oil didn't burn, premixing at 50:1 instead of straight gasoline, would have the same basic effect as dropping 1 main jet size from 500 down to 490. In addition, if your motor was strictly premix and you normally mixed at 50:1 with a 500 main jet you would have to mix at 25:1 to realize a full step down in main jet size. And all of that is assuming 2 stroke oil does not burn.
But we know 2 stroke oil does burn. Source Most modern 2 stroke oils are made from Polybutene feedstock. Polybutene has a flash point of between 215f and 470f. A typically 2 stroke oil has a flash point of about 400f -450f and an auto ignition temp of about 550f - 700f. So when we mix oil into gasoline for premix we are not displacing one flammable fluid for a non flammable fluid we are displacing one flammable fluid for a fluid that is less flammable.
So in summary. Mixing 100:1 premix will have no significant effect on the air fuel ratio. Mixing 25:1 premix very likely has the same effect on the air fuel ratio as dropping 1 jet size at the least and 1.5 jet sizes at the most.
Lots more good info on 2 cycle oil, film strength, piston seizures, etc.
