In the 165 length is there alot of difference between the Pro and the Khaos
On the boost there is. Haven't rode a pro on a na.[In the 165 length is there alot of difference between the Pro and the Khaos
Several both matryx khaos and pros in our group. There is a little difference between them in 165, much more in 155. If bow ties and skis 4 feet in the air is your thing khaos 155. Everyone in our group on a 165 khaos is disappointed in the lack of playfulness. To be fair they are all 850’s. No 9R’s.
My 2021 khaos 155 wheelied bad with the 2.6. I put a camso x3 on it and it actually wheelied less and i believe because it pushed forward more, im not sure. But i definitely prefer the 155 over 165.I helped my buddy adjust the suspension on his recently acquired 2023 9R 155" with a 2.75 tack, that had 350 miles on it. He had ridden it once before the adjustments and said that it was more difficult to ride than his 2020 Khaos 850 155 3" after he rode it one time and said that he wanted it to be more playful. We adjusted the Velocity shocks preload spring for his weight (160-220 LB) and then rode it last Friday. It made a huge difference according to him, however it did not have as much front end lift as the 2020, but rode much better than before.
I believe the 3" paddles on the 2020 Khaos gives more lift than the 2023 9R with a 2.75" lug, plus the lower center of gravity comes into effect also. The 3" trenches more, while the 2.75" propels the machine forward more. We may tweak the suspension more if he requires more lift, but when I rode his 9R it was MONEY! I was able to carve like crazy in and out of the trees and perform tight circles on sidehills with ease. I loved the low end snappy power as well. Now it just needs some clutching work and a can.
The khaos has velocities with more adjustability, just turn your low speed clicker softer for trail riding.My only wish for my 165 Khaos is that it rode a little softer on the chatter bumps. It is getting better with miles on it but would the Pros with Velocities rode smoother?? One thing for sure is the Khaos is super sensitive to shock adjustments and maybe I have just not quite dialed it in for what I am lloking for. Big bumps are no issue.
