I recently put a set of holz trailing arms on my '98 700 rmk. Now I'm having fitment issues, the shock mount on the trailing arms is 3/8" further back from the radius rod mounts than the stock arms, ( 7/8" vs 1 1/4")now the shock springs are touching the tie rods. The stock steering arms are 3 5/8" from the center of the spindle to the center of the tie rod end, so to regain my clearance I would need to use a steering arm thats 3/8" longer, but then it's going to screw up the turning radius and possibly cause fitment issues exiting the bulkhead. Are there different length steering arms used on different models? Would an edge steering arm be longer for example? I may have to put the stock trailing arms back on and that would be annoying because it's taken me a long time to find a set of holz arms for my sled. Any ideas guys?
edit: I made these measurements from the shock mount forward to the spindle, now that I realize the spindle is a different castor angle from a stocker I see where I screwed up.
