not to hijack BD...but here is the billet front crossmember i had made too..had one on my 05 900 and had a buddy copy it for the 06 900 ad he made some for his/his dads 900s as well..so we were all happy, lol..
i talked with my buddy that made my billet one, and he believes the compfusion mounts are causing the stock crossmembers to crack...i cant think of one sled that cracked one that DIDNT have the compfusion mounts...the urethane pucks are a stronger durometer and take the vibs from the sled much better, but transfers it to the crossmember too...
with a bill crossmember, it will never be an issue for sure...(with compfusion mounts of coarse, the ONLY way to go)
Polzinhunter is gonna be making the billet cross members when he gets some time..so theres a market out there for sure..
i cant wait till we meet up Bruce...
we will have to ride each others 975s and compare the difference if any...(Carls vs HTG)
what clutching did HTG tell you to use?
he didn't give me crap for clutching i used my 900 clutching and added weight to the primary.
what do they suggest with carls 975?
BIGGDAWG, what elevation do you ride at. I ride generally from 4,000 - 7,500 ft. Here's a copy of my sled's setup that I posted last season. I'm pulling much more weight than others as well as running a "softer" primary spring. After reading others' setups, I'm not sure how I get away with it, but it works awesome and consistent. I would think the 975 should be able to pull at least as aggressive clutching :
My '06 900-159 has the SLP single and reflash, custom intake and V-Force 3 reeds, as well as about 60 lbs. of weight removed. I ride between 4,000 - 7,500 feet.
My clutching is : Primary - 74g MTX weights with 2g rivet in the middle and 3g rivet in the tip - total of 79 grams, SLP black/yellow spring
(120-310 if I remember correctly).
Secondary - 70-42-.46 with Red/Pink spring.
Gearing was 19/42. With this setup, sled pulled very hard, but was still hitting the rev limiter (8050 rpm) quite often (I was told by an SLP tech I met at the Edmonton sled show that with their package, peak power on the '06 is 7,600 rpm's). I've regeared to 20/42 and although it helped out with the over-rev quite a bit, I still hit the limiter occassionally. To that end, I'm going to try a different primary spring with a 10 lb. lighter finish rate. I've also had very good belt life with this setup. Ran one belt for over two dozen rides last winter and it still looks great. As well, my clutches only got cleaned twice last winter because of belt residue.
Lookin good Bruce! Did u get that pipe welded up yet? Keep us posted!
BIDDGAWG, do you think you'll get enough cool air (running the stock hood) with the stock intake ? The reason I ask, is I am running a similar intake with a Diamond S mesh hood and was concerned that if I put the stock hood back on, I wouldn't get enough cold air to the engine.
Lookin good mr DAWG! Another 900 ready to go before Sean's!![]()
